ignition control module
i have a 1997 chevy tahoe. i rebuilt the engine and ran into problems tring to get it to run. first icm burnt out which inturn took out the pcm replaced both ran rough for a bit and had to replace both again. now replaced the icm for the forth time and it again burnt out after the enging ran for 5 mins or so. any ideal what would cause the icm to get hot and burn up?
Yeah. The ignition COIL has a weak spot in its insulating composistion (plastic) that is allowing secondary voltage ( spark ) to jump across to the primary side (hence the module controlled side) and frying everything. I have had this happen in the past.
I have gotten to the point when I diagnose a no start on one of these and the module is suspect I put a coil on for this very reason. The coil is not that pricey and is good insurance.It is cheaper than replacing everything twice. |
You may want to also check to see if you pinched a harness somewhere when you dropped the engine back in. Also make sure ALL grounds are connected. Electronic components will fair if they are searching for ground
Artificial Intelligence is no match for Natural Stupidity Chet |
| Toasted HEI ignition module? | MorrisonLC | Engine | 20 | 08-30-2009 02:07 PM |
| no power getting to my ignition coil | dearta223 | Electrical | 1 | 08-01-2009 09:36 PM |
| ignition module replacement? | hemi joe | Engine | 5 | 06-10-2009 04:53 AM |
| GM ignition module | thrival | Electrical | 16 | 05-17-2007 10:39 AM |
| Heat sink gel for ignition module | 70bird | Engine | 13 | 04-16-2007 09:31 PM |
