Ignition Control Module
I have a 1929 Model A Ford, built by someone else. I had to replace the Ignition Control Module (brain) which was a 1975 Ignition Control Module and I'm trying to find the wiring diagram. The car won't start. I am not getting a spark in the pickup and I'm thinking that the wiring is the problem.
I have replaced the brain, the pickup, distributor, spark plugs, cables to the spark plugs and I'm hoping that it's a wiring issue. Any help would be greatly appreciated. Thanks. |
Sorry, I'm so aggregated about this. Since I didn't build the car, some of things I don't know.
It's a Ford,460 motor, big block. We aren't getting any power to the pickup from the brain and coil tests that it should be a (+) and (-) but we are getting two (+)'s. Does anybody know the color code for the pickup wiring for that year (1975) - orange, purple and black (closed unit - can't tell) or the brain color coding. |
If you google duraspark II you will get the answers you want.
webpages.charter.net/1bad6t/duraspark.html
| ignition control module | jeff_85 | Electrical | 2 | 09-26-2010 04:04 PM |
| ignition control module? | stroker444 | Engine | 2 | 06-22-2010 07:10 PM |
| ignition control module failures | Brad454 | Electrical | 16 | 10-01-2008 10:07 PM |
| Ignition control module wiring | kane583 | Electrical | 2 | 07-14-2006 01:12 AM |
| control module? | twistedtrik | Engine | 8 | 03-13-2003 05:39 PM |
