For a stock 350, I don't see a problem with the conversion kits plus you have a smaller stock appearing distributor. The other choice is to find a mid to late 70s HEI dist as they still have vac adv and single wire hookup. Aftermarket coil and 8mm wires and your in business.
Good luck, Robert |
Artificial Intelligence is no match for Natural Stupidity Chet |
Have used both the Crane XR-1 and the Pertronix Ignitor kits, on both stock and modified vehicles and had not a problem with either one. Used the Crane twice on modified engines to get the rev limiter feature, used the Pertronix 5-6 times on stock and modified engines just to get rid of the points. All worked flawlessly, but if the distributor bushings, pins, and wear surfaces are shot a new distributor would be a good starting point. You might consider a new points remanufactured distributor and then add the conversion if you have to stay small cap and your current distributor is trash.
Ignition conversion
Thanks very much for the quick reply gentlemen.
If you had to choose between one or the other which would it be HEI or conversion. Is there any advantage to going with an aftermarket system. Look forward to your reply. Thanks Rob |
You distributor is old and is probably worn. A drop in replacement is probably a better solution. If you want to stick with a small cap, bot MSD and Accel make decent units for a reasonable price
AFA points vs. HEI, if you have room for it, the HEI has a better design for the higher voltage.
Points to HEI Conversion
Points to HEI:
http://rmcavoy.freeshell.org/HEI.html This one has Wiring Diagram/Pics. http://www.oldengine.org/unfaq/hei.htm You can get New HiPer HEI distributors on Ebay for under $50. |
The problem I've seen on some of the Ebay distributors is that it's pretty difficult to change the advance curve on some of them. If he goes that route, he might wanna make sure the one he gets doesn't require complete dis-assembly and re-engineering to change the advance curve,
Ignition conversion
Thank you very much for the very detailed information.
I will start the hunt for a good used distributor. I will keep you posted as to how successful I am. Thanks again Rob Fisher |
save yourself time money and problems and just use a stock 1975-early '80's HEI dizzy
one wire BATT connect to any 12v ign source on the fuse panel, and it will be done.. easy as cake.. very simple and more than adequate secondary coltage do away with/ignore all the original small wires to the points dizzy and eliminate the one from the R terminal on the starter solenoid, to the coil no longer needed also. i just snip the end off at the R terminal or yank break it off, can buy a good v-8 chevy HEI for around 20 bucks maybe 30 tops. dirt common.. |
| Help me pick- Electronic Ignition Coil | Francis | Electrical | 27 | 04-24-2006 05:11 AM |
| Camaro VATS ignition and column | RockinLocks4u | Introduce Yourself | 1 | 01-20-2005 11:00 PM |
| starter & ignition stay engaged with key off | 67cuda | Hotrodders' Lounge | 7 | 09-06-2004 10:20 AM |
| Mopar Flat 6 ignition upgrade | Don Coatney | Engine | 0 | 11-26-2003 04:47 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
