Ignition Cylinder Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2003, 09:12 AM
Unhappy Ignition Cylinder Removal
Need help. How do I removal the lock cylinder for the ignition? I have already pulled teh steering wheel, but do not know how to remove the lock out assembly and the directional signal switch. It loks like it may take a special screw driver. Any ideas??
Thanks
69 camaro no tilt wheel
Old 09-14-2003, 09:50 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Not sure on your application but usually there is a small hole in the lock cylinder. You have to insert the key into the cylinder, then insert a small paperclip into the small hole. Turn the key while the paperclip is in the hole aqnd the cylinder should pop out.
Kevin
