Ignition fuse keeps blowing... - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2006, 11:51 PM
I have a 1972 El Camino, 350 with HEI. Every time I turn the key to the on position the ignition fuse blows. Anyone have any ideas on what's causing this?
Old 07-31-2006, 05:04 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Pull the "BATT" wire from the HEI, replace the fuse and turn the key on..if it blows, you have a short on the switch, or the column plug, or the wire to the engine bay.
IF it does not blow...you have a defective coil..test or replace it.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Keeps Blowing Fuse hotrod48 Electrical 17 09-29-2005 12:20 PM
Basic fuse block rewiring y5e06 Electrical 2 06-02-2005 06:46 PM
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 06:23 PM
Blowing ECM Fuse When Ignition Is Turned On aberg12012 Electrical 2 02-09-2004 04:31 PM
