ignition lock help needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2005, 10:14 PM
stea's Avatar
Its not a hot rod but I need help with my kids 89 pontiac grand prix. It has the tilt column. 2 days ago the lock assembly froze up, wouldnt even wiggle. So yesterday I spent all day taking out the column and replacing the ignition lock assembly. Man, whoever designed that column should be shot. It worked fine yesterday but today the key will not come out of the assembly. Car starts fine. What did I screw up?
Old 04-16-2005, 10:31 AM
sedan delivery's Avatar
steering column
it is probably an adjustment. the part of the column just under the ignition lock must turn counter clock wise fully to get the key out. if it a column shift push up on the shifter.if this works loosen the linkage ajustment nut and push the shifter up and tighten the nut..if it a console shift, put the shifter in park , loosen the adjustment nut and turn the shift bowl counter clock wise and tighten the nut. the shift bowl is the part just under the ignition lock. good luck
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 05:11 AM
67 mustang ignition wiring help needed 6t8stang Electrical 2 12-24-2004 11:14 AM
how to remove ignition lock cylinder on a 1981 trans am stoney 81ta Electrical 9 12-13-2003 07:30 AM
What components are needed for a SBC HEI ignition? jpd37 Engine 10 12-01-2003 03:39 PM
