ignition module - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2012, 08:38 PM
ignition module
Hi I just joined the hotrodders forum. It,s an awesome sight. I don,t have a hot rod.What I have is a 66 T bird that I pulled out a 390 and replaced with a 460 out of a Mark 5 That bring,s me to my wiring problem. The 390 had a point system and the 460 has a electronic ignition .The problem Im facing is wear do the red and the red/blue wire that come out of the ignition module go?And there is a brown wire that use to go to the positive side of the coil.If any one could help me with this wiring problem. I would sure appreciate it! Thanks in advance. Ed
Old 06-04-2012, 03:58 PM
LATECH's Avatar
Read down through this article. It will help sort it out, plus theres some cool alternatives.
http://street2mud.com/forum/index.php?showtopic=99
If you need more info, i will bust out a motor manual for ya. Let me know.
ID:	65805   Click image for larger version
ID:	65806   Click image for larger version
ID:	65807   Click image for larger version
Fact is stranger than Fiction
Old 06-05-2012, 04:35 AM
ignition module
Thank you so much Latech. the diagrams will be very helpfull.Im hoping to get it wired latter on today. Ill let you know how I make out .Thanks again
Ignition Module ? hemi joe Engine 16 09-05-2009 10:40 AM
ignition module replacement? hemi joe Engine 5 06-10-2009 04:53 AM
GM ignition module thrival Electrical 16 05-17-2007 10:39 AM
ignition module jpelli Electrical 9 08-04-2006 03:39 PM
Ignition Module musky2 Electrical 3 05-03-2004 02:06 AM
