ignition problem
hi everybody,i have a 75 gmc 1/2 ton pickup,sierra model.stock truck,no extra accessories added on.it has been sitting for a few years.a buddy towed it to my placefor me.it has hei ignition.350 with turbo 350 trans.my problem is it's not starting.it will crank over but not start except when i run a power wire from battery to distributor,then it will fire right up.i have changed the igntion module,the ignition switch and i have traced the power wire from the distributor to the back of the fuse block and it's okay. :confused: any help would be greatly appreciated.i hope i didn't miss anything,if i did let me know
Doc here, :pimp:
Did you check the "BATT" wire for POWER with the key in the run position, and was it 12 volts? If it was, did you again try it during cranking mode? Did it drop to zero? If that happens you have a problem between the run and start set of contacts on the switch, (usually a jumper on the plug) You Can run a secondary ignition from the "R" terminal on the starter and parallel it in at the "BATT" wire to support power during crank as an easy fix for this. Doc :pimp: |
Doc here, :pimp: KEWL! Glad to hear it's Running..and wasn't a major Excedrin moment! :D Doc :pimp: |
| All times are GMT -6. The time now is 04:53 PM. |
