Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition problem???
Old 06-29-2002, 06:53 AM
FASTFORD's Avatar
FASTFORD FASTFORD is offline
Post
i agree with Tom.i run a unilite also.i had 1 problem and had to replace the module inside the distributor.usually,when the module goes bad,it does not work at all. i strongly urge you install the power filter to avoid ruining the module. let us know what fixes your problem,good luck.
