Ignition problem 1961 Chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2009, 07:08 PM
truckboy61's Avatar
I just got a1961 Chevy truck with no working ignition switch. There was a universal switch in the dash but tumbler was jacked! I got a new one assuming it worked ? prior to that twisting the alternator and ignition wires and touching the power wire would work fine! Truck would run fine as long as ignition and alter wires stayed touching each other. Now using the switch, only power to starter but will not fire, if I place ignition and alternator wire together, switch will start but switch will not turn off truck ! some one suggested a on/off switch and separate push start button running power and alternator wires to switch and distributor and cross wire from alternator to push button? It will turn on starter but no fire ? Please help...
Old 06-10-2009, 08:08 PM
S10 Racer's Avatar
http://www.warsprints.com
The reason the motor will not shut off is because you have the ignition wire connected to the alternator wire. When you do this, you are getting 12 volts all the time regardless of the switch position. You really need to test the switch terminals to see what terminal does what. You need a continuity tester to check that. Basically what you want to find is the two terminals on the switch that are internally connected when the switch is in the "on/run" position but are disconnected when the switch is in the off position to break the circuit and turns the motor off.
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 09:24 AM
59 Chevy truck body on 80-85 Chevy frame? texczech General Rodding Tech 11 08-18-2011 08:24 PM
old chevy motor to new chevy truck pwchevyman1990 Engine 4 03-02-2009 12:36 AM
having a wiper problem in my chevy truck, and a taillight fashing problem in my GMC ChevyJim Electrical 5 01-28-2006 07:20 AM
Big Time Ignition problem!!!!! 70chevy Engine 2 06-24-2004 04:41 PM
