ignition problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2011, 09:59 PM
ignition problem
1990 suburban,
I have a puzzeling problem. my suburban runs about 10 minutes the dies as if the ignition has been shut off.
I have checked and replaced the pick up coil , ignition module, coil and ecm.
distributor cap ,and rotor. even after all that it runs about 10 minutes and dies, with no fire. After a couple of hours it will start and run for abou 10 minutes and die.
I would appreciate any input (insite) to this issue.
Old 10-24-2011, 01:10 AM
SSedan64's Avatar
Possibly your Ignition switch is worn out causing the problem. Contacts may be connecting again after they cool.
Many newer Burbs & Trucks have this problem.
Old 10-24-2011, 03:21 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
This truck used an engine OIL PRESSURE SWITCH to power the fuel pump after starting.
It may be a case where the OPS activates OK but when the engine oil gets hot the pressure drops a deactivates the OPS thus stopping the fuel pump.
Or the OPS is bad.
It's easy the test. Run a jumper from the battery + to the "fuel pump prime" test terminal under the hood near the relay box.
This terminal is for testing and priming only. It is unsafe to leave the jumper in place.
vicrod
Old 10-24-2011, 09:43 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
When you say 'no fire' does that also mean 'no spark'? Might want to check and isolate this as a fuel or spark issue.
Old 10-25-2011, 04:36 AM
no spark
yes there is no ignition spark.
Old 10-25-2011, 06:57 AM
T-bucket23's Avatar
Wiki Edits: 26
You have already done the expensive wholesale replacement of parts. It is time to dig out a meter and find the issue. Get a wiring diagram and track down the issue before you spend any more money.
Chet
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 12 05-29-2015 07:57 PM
Ignition Problem malibuman66 Electrical 17 01-24-2006 01:05 AM
ignition problem help please CurtisL Electrical 0 03-13-2004 08:09 AM
ignition problem CurtisL Electrical 0 11-05-2003 12:50 PM
Ignition problem??? Centerline Engine 2 06-29-2002 05:53 AM
