Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ignition problem
Old 05-07-2007, 10:51 PM
dave1939 dave1939 is offline
Last journal entry: Manitoba
Originally Posted by dave1939
hi everybody,i have a 75 gmc 1/2 ton pickup,sierra model.stock truck,no extra accessories added on.it has been sitting for a few years.a buddy towed it to my placefor me.it has hei ignition.350 with turbo 350 trans.my problem is it's not starting.it will crank over but not start except when i run a power wire from battery to distributor,then it will fire right up.i have changed the igntion module,the ignition switch and i have traced the power wire from the distributor to the back of the fuse block and it's okay. any help would be greatly appreciated.i hope i didn't miss anything,if i did let me know
hey docvette,did what you suggested and it worked.thanks.
