Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition Problems
Old 07-26-2011, 12:17 AM
mike 96 ws6's Avatar
mike 96 ws6 mike 96 ws6 is offline
old dog learning new tricks
Originally Posted by hobby28
I had a 110 gph carter fuel pump that was about 6 yrs old and the fuel pressure was fluctuating with rpm it would go from 7 down to 6.
Were you having this same "cutout/sputter" issue with the Carter pump?
petronix coil
Do you have the correct ballast resister feeding voltage to that coil?
