Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition Problems
Old 06-11-2012, 11:20 AM
boothboy boothboy is offline
You have two previous post mentioning insulators between the manifold and carb and that's what I was thinking. I had the same problem with a BBC years ago. I installed the insulator and also a sheet of aluminum painted flat black on the top side. Heat was directed away from the carb. Worked like a champ. Something else to try.
