Ignition Problems - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-12-2012, 01:53 AM
67Mustang Al.'s Avatar
I have a high presure Edelbrock mechanical fuel pump rated at 10 psi on my 347 The holley 650 max operating pressure is 6 psi so i installed an adjustable holley regulator and set the pressure to 5.5 psi and have not had any issues at all using the standard float height measurement I also installed a $10 fuel pressure gauge inline next to the carb so you can watch the pressure while adjusting the regulator. If you had a fuel pressure gauge you could see at a glance when you are at wide open throttle , maybe you could monitor that and see what is happening.
Goodluck.
Al.
  #17 (permalink)
Old 10-29-2012, 02:23 AM
I thought I would post a follow up to this old post. I installed a fuel pressure regulator and shut the fuel pressure down to 4.5lbs. The problem went away immediately, I raced the rest of the year and never had anymore trouble. Thanks for all the help guys.
  #18 (permalink)
Old 10-29-2012, 03:13 AM
Good stuff. Its nice to have finally solved the problem.
Al.
ignition problems 50ford Electrical 2 12-12-2010 01:38 PM
327 ignition problems 327_chevy Electrical 2 10-21-2010 05:43 PM
ignition problems JVunk Engine 4 07-19-2009 10:31 PM
Ignition problems Bjornar Engine 11 10-21-2004 03:03 PM
MSD ignition problems PDSTEVE Electrical 2 03-28-2003 05:33 AM
