My driver {Toyota pu w/22R} has ignition problems and very expensive ignition parts...w/o going into all the problems i'll just say that this ignition problem has turned a dependable everyday driver that gets 21 MPG and hauls most anything i need to move, into a ride that makes ya think about having your c-card w/ya incase something happens. So, that said, what i'd like to do is subsitute a 20R dist. in place of the 22r {has points/condensor & interchanges w/22R} this would allow me the peace-o-mind to take this pu anywhere again. The question is: the 22R comes w/a e-frame ignition coil{?-high tension lead to dist. comes out horizontally, mounts using a intragal frame w/4 bolt holes} that i'd like to continue to run because it looks stock and smog guys get excited w/they see non-stock stuff.....so, how do i match up the condensor w/the coil primary resistance? Or is this even necessary?..Can't find anything on the net so any help appreciated.
Thanks, Randy
Thanks, Randy
