ignition setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2006, 01:54 PM
ignition setup
My 396 build is near complete. I am running a 11-700-9 comp solid roller with 063 oval port closed chamber heads around 11:1 for a full size chevy mud bog truck. I am getting around to thinking about ignition. I am thinking a 6AL MSD unit with an HEI distributer. Should I fool with vaccum or mechanical advance or go with a timing computer or lock it out? The truck will be off road/competition only. Any thoughts on base/full advanced timing. She will be running a 4000 stall.
Old 03-28-2006, 04:29 PM
Unless your running in a minimum vacuum restricted class I'd not worry about vac advance. I would run mechanical though just for starting purposes. Where it will like to be set? I have no idea, 38 or so may be a place to start.
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 05:11 AM
Big Time Ignition problem!!!!! 70chevy Engine 2 06-24-2004 04:41 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
Setup Question (already running) Got Squeeze Engine 3 12-14-2002 10:53 PM
