Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition switch
Thread: Ignition switch
Old 08-16-2012, 05:25 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Sounds as if you have something back feeding into the tranny sircuit..... I'd disconnect anything you've added to the key-on circuit and see if your problem goes away. If it does then you need to find a different pwr source wire etc...... Don't know if this will fix your issue or not..... but if you relaced the switch and it has the same symptom and before....odds are the orig switch wasn't bad
