-   -   Ignition switch (http://www.hotrodders.com/forum/ignition-switch-222882.html)
shee4202 08-14-2012 05:52 AM
Ignition switch
I just replaced my ignition switch with a cheap duralast switch. My problem is still existing. I have a write up in the tranny section with the exact problem that it is doing. My question is, is there a possibility that the switch was a bad switch? Has anyone ever ran into this, replacing a ignition switch and finding out it was bad?
EOD Guy 08-14-2012 05:42 PM
I don't read the tranny section...... but there is always the possiblity of a bad new part. What's the issue?
JeffB 08-15-2012 12:55 AM
Switch Problem
Original switches in older cars are not made to handle increased loads,my '54 has A/C,electric fuel pump and electric fan and sound system it did not last long so I read this: Custom Cars Classic Hotrods Streetrods-Watsons StreetWorks and added the 70 AMP relay and additional relays to these accessories as well as the headlights which are now much brighter and since adding the relays have had zero problems.
shee4202 08-15-2012 04:38 AM
So since the switch is not made to handle additional loads, do you think that by tapping into the two power wires on the switch for a remote/security system would cause the faulty codes
shee4202 08-15-2012 04:40 AM
Well, basically I'm throwing a few codes:
p0740- torque converter clutch circuit
p0785- shift/timing solenoid
p1860- solenoid circuit electrical
After I clear the codes they seem to keep pending. This doesn't happen constantly but at least once a day when I go to take off from a stopped position I have to have the pedal almost to the floor just to get it moving. It's seeming like when it does act up I'm missing 1st and OD. At this point I pull over and clear codes, even if there is none to clear, and then turn the truck on and off a few times. It seems to act normal again after that.
After doing some research I found someone having the same exact issue and throwing the same codes. He changed the ignition switch and it worked. It seemed to work for several other people as well.
I change the ignition switch and its still doing what it was doing, which is exactly how the people in my research were explaining it.
Do you think that the ignition switch that I put in was faulty? I can't really see there being anything wrong with the tranny because when its not acting up, it's working fine.
EOD Guy 08-16-2012 04:25 AM
Sounds as if you have something back feeding into the tranny sircuit..... I'd disconnect anything you've added to the key-on circuit and see if your problem goes away. If it does then you need to find a different pwr source wire etc...... Don't know if this will fix your issue or not..... but if you relaced the switch and it has the same symptom and before....odds are the orig switch wasn't bad
JeffB 08-16-2012 12:13 PM
1 Attachment(s)
X2 Instead of tapping into an existing circuit stop by NAPA and pickup a fuse holder the type that will accommodate 4-6 fuses and run a 8-10 gauge feed wire direct off the positive battery terminal.I like this style shown in the picture to add circuits.
shee4202 08-16-2012 02:08 PM
I think that I figured it out. I spoke with the crutchfield tech. today, the one who helped me install the remote start system. Seems that I missed a wire. Before he told me that there was no ignition 2 wire. Today he looked over the diagrams again for my truck and found that there is a ignition 2 wire (white). I asked if not hooked up, would it throw tranny codes and he said it would. So I hooked it up and so far so good.
Before I was either getting tranny codes on the "service engine light" or I was getting pending codes. After making the change I immediately checked for codes. There were none showing and none pending. I'm thinking that that did the trick. I hope at least.
EOD Guy 08-16-2012 08:27 PM
Good to hear you got it figured out
