ignition switch removal problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2006, 06:02 AM
Hi Guys!
We're half way through a dash harness install and we've run into a problem with the ignition switch. Seems the previous owner of my 68 firebird buggered up the switch and we can't figure out how to remove it. I've tried the paper clip in the little hole and turn the key method and no go. So what should I try next? I'm thinking of taking a dremel tool to the nut, but don't know if that will free up the switch anyway. Anyone got any ideas?
Jerry
Old 12-07-2006, 06:21 PM
russlaferrera
Last wiki edit: Threading tips
Wiki Edits: 2
ignition key removel
I may be wrong. But do you have to turn the key counterclockwise while pushing on the paper clip. There is a small brass pin w/spring that has to be released to disengage the lock....russ
Old 12-07-2006, 07:22 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I use a little tiny drill bit.
Push in the plunger with the key in the Accy pos, keep turning the key til almost horizontal---it should release
Bryan
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 06:04 PM
I want to install an underdash ignition kill switch in my 67 nova...can you help? batman09 Electrical 40 05-15-2005 09:47 PM
Removing/Installing ignition switch fourbyfourblazer Electrical 6 01-13-2005 10:23 PM
ignition switch removal jackyandjoe Interior 2 09-18-2003 07:05 AM
Ignition problem??? Centerline Engine 2 06-29-2002 05:53 AM
