Ignition switch replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2005, 10:04 AM
I have done this in the past, but cannot recall the procedure. I am replacing the ignition switch on a 1967 Chevelle Malibu. Is there any help out there?
Thanks in advance, Bill
Old 05-21-2005, 03:28 PM
docvette's Avatar
Wiki Edits: 12
Switch
Doc here,
67? Can't remember, wasn't that in the Dash not the column? IT been like forever...
If so, the Trim ring just unscrews from around the outside of the Cylinder, and should If I remember correctly, have a Backup nut you can back off.
Just pull the plug, remove the ring, and withdraw it from the rear of the Dash..
If It's a Column, you have to remove the wheel into the Signal bay, loosen the two Column Support bolts, and slightly lower it, then remove the hold down screw and Locking pin.. then with withdraw the switch...pull the plug, and reverse it to reinstall...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 05-21-2005, 09:57 PM
Some old cars had a tiny little hole right next to the keyhole. If so, you may have to remove the lock cylinder before you can get the nut off. Stick a thin wire (paper clip, etc.) into that hole & push inward while turning the key counter-clockwise past the ACC position to release the cylinder. Jiggling may be required.
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Ignition switch replacement on 89 chevy truck Mighty Mouse S-10 Electrical 3 04-17-2005 01:54 PM
Removing/Installing ignition switch fourbyfourblazer Electrical 6 01-13-2005 10:23 PM
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 7 10-24-2004 11:37 AM
Ignition Switch Burnt out? 61ChevyTruck Electrical 5 03-20-2004 04:08 PM
