Ignition Switch or Solenoid ? Will not start 62' Impala - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-27-2011, 11:38 AM
starting problems
Originally Posted by Sin7
The more i look at my drawing and my notes i am confident it's the ignition switch.. I believe the ignition switch is not sending 12v through the violet wire to the "S" terminal...
And there would also be no need for me to check power at the "I" terminal because that wire has been decommisioned when it went from points to hei.
Hi, Just like to ask you if you were able to find the problem. I have a 62 impala with the same issues. I changed the starter and the car will not start. checked the battery was not the problem.
Need some help or info can you email me like to pick your brain try to get my car running.
you can reach me at fathogz@ sbcglobal.net.
Thanks Ray
73 Impala Ignition Switch Cylinder Jammed jonathanks Electrical 2 03-10-2011 04:44 AM
starter solenoid shorting ignition junkyardjeff Electrical 5 03-24-2007 05:15 PM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 07:04 PM
Ignition Switch?? or what ponybuster Electrical 13 12-29-2003 10:17 PM
Emergency - 67 Impala Ignition Switch (dash) doctormidnight Electrical 2 12-15-2002 05:29 PM
