ignition switch wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2009, 01:49 PM
Last journal entry: 36 hemi chevy
This may or may not be simple questions, but here goes. When the ignition switch is in the ACCESSORY position it supplies voltage to the fuse panel. When the ignition switch is in the ON or RUN position does the fuse panel still get power from the ACCESSORY? Also when the ignition switch is in the START position there is power from both the RUN and START positions, right? I'm trying to wire an 80's Camaro column, when I turn the key to the RUN or ON position I get power from both the ACCESSORY and Run positions. When I turn the key to START I should still get power from the Run position,right?
Old 01-29-2009, 02:10 PM
Joe G's Avatar
I usually don't deal with anything as new as an '80, but here is how most ignition switches work.
Terminals on switch:
Battery power
Accessory
Ignition
Start
Switch positions/functions:
Off = no power to Ign, Acc, or Start terminals
Accessory = Power to Acc terminal only.
Run = Power to Ign and Acc terminals.
Start = Power to Start and Ign terminals - some switches also turn the Acc terminal off while cranking while others leave it on.
Note: some ignition switches do turn the Ign terminal off while cranking. On vehicles with this style switch, there needs to be an alternate way to get power to the coil while cranking the engine. Typically, on these systems there is a wire from the starter solenoid that bypasses the ballast resistor and provides the coil with full voltage for a sharper spark while cranking.
Not sure on an '80 though. That's a late model as far as I'm concerned
Hope this answers your question.
Joe G.
Old 01-29-2009, 03:51 PM
just a different way to say it
ACC=no power to the ign coil so you won't burn up the coil while you listen to the radio for 4 hours with the motor not running....
some fuses are batt direct/always hot (interior lights, clock)
some are only hot with the key at "on" or "acc" (heater fan, radio )
some can be either (brake lights or back up lights)
unscrew the fuse panel so you can look at the wiring on the back side,,easy to follow the "batt direct path" or "ign on/acc path" from the 2 power (likely #10 size) feed wires into the panel thru the fuses
Old 01-29-2009, 04:50 PM
thanks gentlemen, I was wondering about double feeding the fuse panel with power coming from both the ACC and RUN when the the switch is in the RUN position but it looks like they feed different items in the fuse panel.
cheers
Bill
69 camaro ignition switch schematic mvara71 Electrical 8 01-18-2008 07:21 PM
neutral safety switch wiring ford column to 700R4 49willard Electrical 7 12-01-2007 06:27 PM
72 chevelle ignition switch assembly problems customdrumfinishes Electrical 9 08-10-2006 06:06 PM
Ignition control module wiring kane583 Electrical 2 07-14-2006 02:12 AM
66 Chevy Ignition Switch Problem 66Caprice Electrical 3 10-04-2005 10:10 AM
