ignition swith problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2009, 02:11 PM
302 Z28's Avatar
I wish to relate a problem I am having with the new style ignition switch from a major street rod supplier. This is the switch that uses a key that looks like a real automotive key instead of a golf kart looking key. Before I actually started driving my 34 and after I had it wired with a Painless wiring harness w/ the new ignition switch I noticed a problem. Several times after turning to the start position then releasing to the run position the starter would stay engaged. There would commence several frantic seconds of working the ignition switch back and forth trying to get the starter to disengage. Eventually it would, though with some panic and effort. I called the supplier to report the problem and of course they had never heard of it before but agreed to send out a new switch. I installed the new ignition switch and have been driving the car for several months since. Today I'm driving along and I hear a noise from the engine compartment. I stop the car and turn the ignition off but the noise continues. I get out of the car and raise one hood panel to see the engine still turning over and the noise of a starter grinding away. Recurring memories of the last ignition switch problem flash before me. I jump back into the car and reach behind the console to unplug the ignition switch which immediately stops the noise.
Come Monday morning I will be going down to our local NAPA store and purchasing a good ole Echlin old style GM ignition switch. I am quite sure that if I called the supplier again to report the problem it will be like they heard it for the first time.
Update: Just noticed that the key I am using which is for the replacement ignition switch also fits the original ignition switch.....how convenient
Vince
Old 02-01-2009, 08:25 PM
life is a temporary assignment
Vince..On the one's with the nuts on back.I notice that if you put the center nut to tight it will cause that..I had a few that did me that.And i backed off on the center nut a little.And it didn't do it again.Not sure if you have the one with the three nut's and one right in the middle.If so back off on the center nut and see if it work's.
Old 02-01-2009, 09:06 PM
302 Z28's Avatar
Thanks for the tip, but this one just has a 4 pronged plug, no nuts.
Vince
Old 02-01-2009, 09:14 PM
blower idle rpm problem Ratoflic Engine 7 12-01-2008 03:31 AM
350 ignition problem xxxtonyrusxxx@yahoo. Engine 10 06-30-2007 02:34 AM
66 Chevy Ignition Switch Problem 66Caprice Electrical 3 10-04-2005 09:10 AM
Strange problem with ignition...... talunceford Engine 5 11-08-2004 06:25 AM
Motorcycle ignition problem. help! FASTCHEVY Electrical 15 05-03-2004 04:51 PM
