ignition system - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2014, 10:02 AM
50 ford
ignition system
what is the best distributor to use on ignition system,hei or pertronix. running sbf 302 ho. has duel point system now
Old 01-18-2014, 10:15 AM
Last journal entry: New Rev wheels and BFG KDW II tires
I guess it depends if you want to run an external coil or not. I love the Performance Distibutors HEI I run on my 351 in my 77 Bronco. One wire hook up is tough to beat. It is bigger than the Pertronix but I have no problem with any clearance issues. I doubt there is much if any performance difference.
One nice thing when you buy a DUI is they will do a custom curve for you. At least if you buy it through their web site.
http://performancedistributors.com/p...1-289-302-cid/
The Following User Says Thank You to 64SS327 For This Useful Post:
50 ford (01-19-2014)
Old 01-18-2014, 12:39 PM
JeffB's Avatar
I like the HEI it's been in my ride for almost 5 years,to run a 14" air Filter you may need a 2" carb spacer to clear depending on your intake choice,check out my picture here.It is actually this one: SBF Ford 289 302 HEI Ignition - Blue Cap Distributor w/ 50K Coil Small Block 260 The Internals are interchangable with SBC HEI's so parts availibility is a no brainer and it works fine for a street cruiser if you got a little extra in your wallet you could buy this for bragging rights:Flame-Thrower Ford 289 302 Small Block Windsor Street Strip HEI Distributor Blue
Name:	'54 Engine & AC 004 (Medium).jpg
The Following User Says Thank You to JeffB For This Useful Post:
Old 01-19-2014, 08:14 AM
50 ford
ignition system
thanks for the info, will check into both systems for my needs.
Ignition system. mrdreex Engine 14 04-11-2008 04:24 PM
Ignition system dutch paul Electrical 10 03-27-2006 08:33 AM
Which ignition system? tornado-tech Engine 2 01-29-2006 09:10 PM
Ignition system Ratoflic Introduce Yourself 1 12-03-2004 09:20 AM
Ignition system fred56 Engine 1 08-31-2003 07:47 PM
