Hotrodders Bulletin Board
| View Poll Results: What Igniton System Do you prefer? And Why? (specify in a post after voting) | |||
| Stock HEI System |
51 | 46.36% |
| Stock Duraspark system |
8 | 7.27% |
| Other (And please specfy in a post, and why..) |
51 | 46.36% |
| Voters: 110. You may not vote on this poll | |||
#1
Which Ignition System Do you Prefer? And Why?
Doc here,
Which Ignition System do you prefer and Why? I thought this poll ought to be handy for "Shoppers" of New Ignition systems. Lot's of Pro's and Cons out there, so let's get them in one spot to wade through the types to help folks decide.. Please Qualify your answer, with : "Used brand X for 15 years, and never had a failure" OR: "Used Brand X , was a nightmare Because, No instructions, never ran right, failed after install "... Ect... Thanks! Doc ![]()
Aftermarket Solutions Electronic & Electrical Innovations |
#2
I like accel because it is cheap and reliable. A lot of people will prefer MSD and there are good, but there are others that will do just as good of a job for cheaper. All MSD means is multiple spark disscharge and is most noticeable at low rpm's. Because at high rpms it will become pretty much a singal spark anyways, it will keep the spark more stable though.
#3
Well I too have used Accel ignitions but I had a problem at high RPM in my Mustang, I would start losing constant reliable spark. Switched over to MSD and never had a problem. I ran the MSD 6-al offroad ignition in my 91 F-150 with a 302 and 35" tires. Buried the engine underwater many times and my ignition never quit. I am currently putting an MSD ignition in my 69 Nova. for my daughter,(rev. chip set to 1800). So I would say my vote is MSD. Not much more expensive and more reliable than most. But opinions are like a#$holes,everybody has one. LOL..
#4
Accel products are tops in quality and were around long before MSD. I've never had an Accel part fail or taken one back claiming failure when in aftermarket sales. I'm running the 300+ at the moment. One very important feature is the rev limit set by dip switches. It cuts the spark and not the fuel as in the Ford system does which can be a disaster using a poweradder. Having said that, it is an add on for the stock HEI system as it uses the stock TFI type distributor and components. |
#5
In this order,
MSD for any forced compression engine, and any and all racing applications. Small body HEI, as done by me, yes, very biased, from many years of hands on experience. Modified large cap HEI, remove that junker epoxy coil from that cap, use an oil filled round coil somewhere away from that distributor. Drop-in, Mallory Unilite, NOT their magnetic nightmare. Stock points and aftermarket points setups. I don't like most other systems, just plain junkers, like the used to be a really good setup Accel, made in the USA, to the available this minute Accel, now made in Taiwan. PerTronix, trash, Comp-U-Fire, Breakerless, no, thanks. |
#6
well, that's a loaded question for sure!!! for me, stock and lightly modified applications i like hei. reliable, easy to install, and parts readily available. high performance street, mallory, accel, msd. more of a brand preference than anything, i've had great luck with all of them. for racing, i've ran accel 300+ and think it's the way to go for all but the most extreme combos. mallory has been making ignitions for nearly 50 (i think it's 50, could be wrong though.......msd started in the 70's. by then, mallory was already old......)years before msd, and i still think they make a superior product. don't get me wrong, msd makes some good stuff, but alot of there ignitions are sold on "stuff". there have been ALOT of failures with their newer ignitions, and most of them (the higher end ones like the digital seven programable) have more features than the average racer will ever need. any way you go though, none are a bad choice. just make sure you shop around and get what you need. don't waste your money on one that has features you'll never use. some of the ones out there now need a laptop just to set up!!! btw, i'm going to msd on my new car buildup, not because i prefer them, but because the features they have i need........
#7
I'm using an MSD BTM on the Nova, but had an Accel dual point (before electronic/magnetic was readily available for my car) on my '65 GTO. It was a good piece, but after about 500 miles it sheared the roll pin. It was hard to track down. It would idle OK considering the cam I had and would free rev fine. Put load on it and it completely fell apart. When I got it home and got a light on it the timing was all over the place and I figured it out.
#8
I like MSD 6al. Because of ease of install and the noticable idle improvement. If I were dealing with a stock engine I would choose "Stock HEI" I assuming your talking about G.M. because its easy to diagnose and install.
#9
I like mopar Chrome box.Simply because that's what goes in my car.I've had good result too.I like the oem look.
#10
Crane
I ran the CRANE XR700 points conversion and coil in a Autolite distributor and it went 10years with out a problem to pass 7000rpm.I only replaced it as I wanted a new distributor and a rev limiter so chose a Mallory distributor I got with a improved Unilite called E spark and Hyfire VIA, both untried but very good priced and digital too.
#11
Good Idea Doc...
I use the MSD Pro Billet Tach Drive Distb on My 65 Vette with a ZZ502. I pulled the stock HEI only because it didn't have a tach drive. Now I know there is a GM HEI Tach drive available but at $400.00 and plus buckies I said no. I went with the MSD ..$100.00 some dollars less. I have used the MSD before in another set up. It was verey reliable..never any problems. I also use the MSD 6al Box and Blaster Coil. I would have rather had the GM HEI Tach drive...Maybe it's just that I like GM Hi Proformance Parts Stuff....but MSD is also a solid Brand.. I would recomend MSD ..Lots of them in use good factory support.. Last edited by Viet Nam Vette : 01-31-2006 at 09:05 AM. |
#12
Easy one
The best ever is the GM HEI .Best racing is a MSD modified HEI. I'm sure
#13
I like old points distributors because folks say I have no point. I can tell them I do. Plus you can find them almost anywhere. I bought a mallory dual point at a garage sale for 2.00. They adjust with a matchbook cover. You can diagnose them by watching them work. You can swipe the O.L. nail file and file on them and get another year out of them when they get wore out. I don't own anything that will rev high enough to get point bounce. Someday I'm gonna put the old unilite conversion that I bought at turlock in '94 or 95 in Old Yeller and see what all the fuss is about. It is so old it came in a vinyl covered hard case box with flocked padding inside. later,mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
#15
Not being a "Racy" guy anymore, a stock system works fine for me.....I have kept the points in my Pontiac, just so I can use my old dwell meter once in a while.........It does have the clear plastic cap on it though....looks cool at night.....
