Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition system info................
Old 08-23-2004, 10:41 PM
Seon's Avatar
Seon Seon is offline
You'll need to provide a hot wire with a full 12 volts to the HEI and is controlled with your ignition key that will turn on and off with the engine. I tapped a 10 gage wire from the "acc" on the fuse box to the HEI. Also, you'll need to re-gap your spark plugs to about .045".
