Ignition system info................ - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-01-2007, 09:03 PM
Last journal entry: steering column
ignition problem
hi everybody,maybe someone can help me with this.i have 75 gmc pickup that won't start.cranks over but won't start.if i run a power wire from the battery to the distributor cap terminal,truck fires right up.have changed ignition switch and checked wire to fuse block and tried changing fuses,no luck.i'm overlooking something but not sure what.any help would be appreciated.thanks,i hope i put this post in right place
  #17 (permalink)
Old 05-01-2007, 11:10 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
answer in your other post..
I guess this was moved here..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
  #18 (permalink)
Old 11-23-2007, 01:56 PM
JOEPATRICK2's Avatar
Last journal entry: 69 Camero Resto
94 Malibu starting problem
My son has a 95 Malibu automatic v-6 and when you start it and drive and then stop it some times not all the time it will not start back up. The engine turns over just fine and the longer you try to start it the longer it will take to start. On the other hand if you go shopping for a while and then come back to the car it will start right up again. It's got me scratching my head with this problem because I'm not sure where to look for the problem and the engine runs smooth and good.One would think if was in the ignition system I would have a miss or it would be there all the time but now I'm also dealing with a computer so I thought someone out there might have run across this problem before and save me some time on what to look for or just take a stab at what you would do two heads are better then one,,thanks,,Joe
  #19 (permalink)
Old 10-11-2008, 10:10 PM
Originally Posted by Atomic Banana
Drug this thing home on Saturday and am not getting fire. Getting voltage to the coil, the points are firing but cannot get anything out of the cap. I say that, have only tried grounding out a plug out of the engine and got a bunch of nothing. New coil, cap, button, wires, and plugs.
Any ideas? Been so long since I messed with points I do not remember how to test half of this stuff!
Make sure that you have a good engine ground clean and tight!
