Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition system info................
Old 04-27-2006, 12:11 AM
chileelky chileelky is offline
ignition max amp
I make a mistake. Bought a Flamethrower II coil having an original Ignitor. There is a warning on the coil not to use together (because the final ignition amp will be too high?
What will be the max amp recommended (69 gm 307, taylor braided wires, approx 12 volts on the coil + when running, coil 0,600 ohms)?
What damage may occur if used?
Appreciate your help.
