Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition system info................
Old 04-27-2006, 12:56 AM
chileelky chileelky is offline
Thank you Doc ĦĦĦĦ (amazed for your late night reply)
I am very amateur, but surfing through the posts (lots of yours) have helped me a lot (not too many info sources here en Chile).
If I get it right, that combination will make 20 amp on the spark plug wires, with risk of freeing them. Will a ballast resistor cure this?
I took the car for a 15 min ride, after installing an MSD 5900, the Flame thrower II coil, the Taylor SST wires (Ignitor I was installed before) and runs far.
By the way, I installed all this trying to low HC omissions to pass next control, so any help on how to kill HC will be greatly appreciate also.
Long live Chevy'sĦĦĦĦĦ
69 camaro 307
69 C-10 six-liner
67 elky 283??
