Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition system info................
Old 04-27-2006, 02:27 AM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
That would be on the secondary side of the coil..not too much to worry about there if you have 8 MM spiral core wires and proper gapped plugs (around 45)
The primary is the side pulling around 20 amps..The + side..It may not be compatible with your Ignition module I really couldn't say for sure..you need to check the instruction sheets for both units for compatibility.
A ballast resistor may not be required for that coil either, another thing to check on your data sheets, It could just make it run worse..At the very least, It will defeat the purpose of why you put the upgraded coil on there to begin with.
Doc
