Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ignition timing
Thread: ignition timing
Old 08-25-2003, 01:08 PM
Dave E Shank's Avatar
Dave E Shank Dave E Shank is offline
I would like to chim in with a further question... my sbc 350 runs hot at idle in traffic, about 230 degrees. Local hot rod supplier is telling me the cure is to advance distributor until rattle and ping under load, back off a little and engine will run a lot cooler??? Have any of you seen this in action?. Right now I am running about 8 degrees BTDC. But this sounds so off the wall to me. Any comments would be appreciated.....THANKS....DAVE
