Ignition Timing on a 383 for Marine Use - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2011, 09:46 AM
The mobile view is crap
I finished getting my sbc 383 together and now the engine is on my test stand. I have never really done much with a carb'ed engine with a manual distributor. I am curious of what my timing should be set at and taking proper procedures to do it. Do I need a timing light with advance? The engine has a BID (Breakerless Integral Distributor) Ignition. With the stock coil.
Old 05-07-2011, 10:20 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
marine ignition curves are very similar to street just without the vacuum. My 350 marine vortec is timed at 10 degrees with 34 total. The curve is set to start coming in at around 1800 and all in by 3500.
Old 05-07-2011, 10:22 AM
curtis73's Avatar
Wiki Edits: 16
What heads, compression, and cam?
Old 05-07-2011, 12:33 PM
062 vortec heads, 9.35 compression, I am not really sure what the cam is, the cam is what I took out of the stock 305 engine. I planned on running 89 octane in my boat, should I be running something different?
Old 05-07-2011, 02:28 PM
the cam is a hydraulic roller cam, before I built this engine I had another thread going and they were telling me to run the 305 cam in the 383. The drive is a volvo penta sx drive with a 1.66 gear ratio. The prop is still up in the air. I have to get a new prop for it anyways because the aluminum prop on the boat is pretty beat up. The boat is a 2001 Glastron GX205.
The cam that I was going to originally run in this boat is this
http://www.cranecams.com/product/car...detail&p=24200
Then after talking to people they talked me into just swapping the cam and just increasing the cubic inches of the engine.
Engine Specs:
4.030 bore
3.75 stroke
stock 305 cam
Edelbrock Peformer RPM air gap intake
062 vortec heads
Holley 600 CFM Vacuum secondaries carb
Would you suggest any changes, and if you do what and what would you change it to?
Old 05-14-2011, 11:11 PM
I was working on the ignition system today and noticed that the coil on the boat said for use with external resistor. I don't see a resistor anywhere in the wiring for the coil. I don't even see on in my service manual wiring diagram anywhere. I am thinking that someone just replaced the coil with the wrong one and didn't even pay attention to it or know that there was a difference. The coil has to have a resistor, right? I bought a coil that says "no external resistor required" should I just install this or should I do something else?
Ignition timing Scandinavian Engine 19 04-12-2011 12:23 AM
Timing setting for 1976 350 marine engine hrwj51 Engine 3 07-12-2010 09:22 PM
Ford 302 marine motor timing setting. digithead1 Engine 0 05-26-2009 12:53 PM
Marine Ignition System TOB Engine 10 10-30-2006 11:22 AM
ignition timing amblessed4life Engine 1 05-21-2006 05:53 PM
