ignition timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2005, 08:53 PM
chev kev's Avatar
ignition timing
hello chev kev here .its been a while but im back and have a question maybe someone can help. my question is about my ignition timing. i have a 74 nova 350 with a hei accel dist ,edelbrock 600 carb. for streetand soon for strip
should i hook my dist vacuum line to full vacuum or no vacuum at idle.
thanks for any help
chev kev
Old 03-21-2005, 08:57 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Theres tons of arguments on this in the knowledge base!
Old 03-22-2005, 12:04 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
strip use
Strictly race usually uses no vacuum advance. For strip street use the vacuum port on the passenger side of the carb. It is designed to not advance at idle. When on the strip the throttle is wide open and there is not enough vacuum to advance the distributor. Your main concern is total mechanical advance. Should come in at 1300 rpm and be all the way in by 2500 rpm. Set total time at 36 to 38 degrees.
Old 03-25-2005, 07:18 PM
pink63impala's Avatar
Last journal entry: my 63
would that be the top or bottom vaccum on a holey?
Old 03-26-2005, 03:24 AM
Tazz
vaccum to use??
The pass side rear of the carb...
Tazz
Rat Rdos Rule!
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
5.0 liter ignition timing GTpony Engine 5 05-31-2004 11:35 PM
SBC Ignition Timing snod83 Engine 1 04-19-2004 04:42 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
