ignition timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2006, 03:59 PM
amblessed4life's Avatar
ignition timing
im working on a 1987 ford ranger 2.9 v6 EFI 4X4 . I need to set the timing 10 degree's BTDC. ( BEFORE TOP DEAD CENTER) . I was needing help to understand what it means an how to set it. im setting the ignition timing , or the cam timing . I have the truck running but it is loping real bad dont have no power. When you go to hit the gas it dies.
Old 05-21-2006, 05:53 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I'm not a Ford Guy at all...
But I think on that system you need to disconnect the SPROUT plug before base timing it..
Check your manual, or maybe one of the Ford guys can chime in..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Setting timing curve with HEI Ignition Mad Maggot Engine 15 08-07-2013 12:07 AM
Ignition system info................ poncho62 Electrical 18 10-11-2008 11:10 PM
ignition timing (in relation to rpms) KNanthrup Engine 8 05-21-2006 05:16 PM
Bb Chevy Ignition Timing leejoy Engine 13 03-01-2006 03:09 PM
SBC Ignition Timing snod83 Engine 1 04-19-2004 05:42 PM
