Ignition Timing Affect Vacuum - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2008, 05:14 PM
lanceks1's Avatar
MELLO YELLOW
Last wiki edit: Electric cooling fans
Last journal entry: Led's are Good.
Wiki Edits: 2
Does advancing, or retarding ignition timing affect vacuum available at the manifold? Aside from changing engine RPM.
Old 01-10-2008, 06:43 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Old 01-10-2008, 07:51 PM
spinn's Avatar
it can affect cranking vacuum as well.
most high compression engines wont even crank with 20 degrees inital timming.
Old 01-10-2008, 08:01 PM
Set inititial advance to around ten to twelve degrees. Hook your distributor vacuum advance can directly to a full vacuum port, not a timed port. You won't have any trouble cranking and when the motor starts the vacuum advance will give you another seven to ten degrees of advance which is just what you want.
Old 01-11-2008, 11:21 AM
spinn's Avatar
manually retard the start timming?
Old 01-11-2008, 03:10 PM
No, that would be neither cheap nor easy. Just set the initial timing to about ten to twelve advanced. Any engine will crank easily with that. connect the vacuum advance to full manifold vacuum. Don't use the so called "timed" port on the carb. That port is a smog crutch to make the motor run hotter at idle and reduce oxides of nitrogen. Also gives you a crappy idle and overheating in slow moving traffic. When the motor starts the vacuum advance will give you more advance at idle. Your motor will run smoother at idle and cooler in traffic. This will give you a faster idle which you can slow down with the curb idle screw but your advance will stay the same.
Ignition timing woes KNanthrup Engine 16 07-22-2007 10:18 PM
Ignition Timing (again....) pass-n-gas Engine 22 06-12-2007 11:47 PM
350 chevy timing tiresmoke55 Engine 7 01-14-2006 11:55 PM
Timing ?'s, Idle Speed and Ported vs Manifold Vacuum JoeS Engine 5 11-03-2004 01:34 AM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 08:52 PM
