Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition timing woes
Old 07-10-2007, 08:09 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Originally Posted by KNanthrup
Fresh crate 350, maybe 2000 miles, cam is Comp XE274H 230/236@.050 .520/.520 lift, 10:1cr, stock cast pistons, Holley 4150 DP 750cfm carb, std HEI dist., bosche platinum plugs, 8.5mm MSD wires, Edelbrock performer RPM intake, dual 2.5 exhaust thru 1 5/8 shorty headers, all in an s-10 pickup weighing ~3000lbs, trans is NV3500 5 speed manual, rear gears are 3.73
Have you checked to see if the Balancer has spun?
R
"SlowRide66"
"Illegitimis non carborundum"
