Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ignition timing woes
Old 07-14-2007, 11:47 PM
baddbob baddbob is offline
I don't think 4 more degrees is going to throw your intake closing point off enough to cause problems unless you were on the very edge. Do yourself a favor before tearing the front end down and retarding the cam-do a compression check to see where it is. 150-170 psi and you're Ok for pump gas, 180+ and it'll take some tuning and probably octane booster to make it work. Let us know what she's pumping, Bob
