Ignition wire length - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2012, 04:50 PM
Bought a set of beside the valve cover aluminum wire looms for my 400 sbc from Skip White.
Before I buy new HEI wires, I would like to know which are longer (or would be best) for threading behind the heads and thru the looms: over valve cover, under header, or cut to fit universal.
Leaning towards Taylor 90 degree HEI wires with the double clip plug ends.
Have followed your website for years, finally decided to join.
Thanks for any help you can give me.
Old 01-13-2012, 12:27 AM
SSedan64's Avatar
Universal should be longer.
Old 01-13-2012, 05:44 AM
TroyBoy's Avatar
Psychomotors
Like Sedan sez-universal. You always end up with weird sizes that don't work for squat with the pre-cuts. I have been buying the universals and running my wires behind the valve covers and under the headers on SBCs with no problems .
Old 01-13-2012, 09:44 AM
techinspector1's Avatar
Wiki Edits: 326
Some fellows will recommend separating the wires from each other by about an inch to prevent transient spark from one wire to the other, causing a mis-fire. Also, using a material such as wood or plastic that will not transfer current will make a better separating medium than metal stands.
Old 01-13-2012, 11:43 AM
topwrench's Avatar
Last journal entry: fish carb
On a chevy you still have to cross some wires somewhere!
Usually on top of the cap....
Old 01-13-2012, 11:48 AM
JeffB's Avatar
Anytime you run custom looms universal is the way to go,in most cases you will need that extra length.
Old 01-13-2012, 12:00 PM
Irelands child's Avatar
Universal Taylor Spiral-Pro in Made-For-You nylon looms. There was probably enough wire left for a couple of 6 cyl engines
Irelands child
Old 01-14-2012, 09:59 AM
Thanks all for your answers.
Appears my best bet is to buy a set of universal Taylor wires and custom cut
and fit.
I am not worried about crossfire between cylinders, as I also bought a set of Skip White chromed plastic seperators which came with 4- 4 hole dividers for near the cap and around the back of the cylinder heads.
Ignition wire to Coil 1bbr60 Electrical 5 04-28-2009 08:06 PM
ignition wire spaghetti atotalnincompoop Electrical 3 07-09-2008 02:30 PM
Burnt Ignition Wire--why??? 23T Electrical 2 05-14-2006 07:05 AM
Wire dress length Thom Laybourne Engine 6 10-29-2004 07:34 PM
Ignition wire bracket mitmaks General Rodding Tech 2 08-01-2004 09:25 AM
