ignition wire spaghetti
i have a wh1001 harness, i'm a little confused as to how to hook up my ignition circuit.
i have a jegs ignition panel' here is the diagram for that... http://i35.tinypic.com/zwjluu.jpg there are 6 wires thast go to the ignition, here they are... http://i34.tinypic.com/2egcwfb.jpg they are listed in my instruction (little orange book) as... pink-ignition eng red-ignition then together in a plug... red-ignition switch power pink-ignition switch coil purple-starter brown-ignition switch acc i don't want to hook it up wrong and short something. there is no key just this switch for starting. what do i do? thanks greg:) here's a pic of the switch too... http://i38.tinypic.com/2lsfx5h.jpg |
1 Attachment(s)
As for the brown wire aka accessory feed you can either hook it into the same spot as the pink or run another toggle for it. here is your pic modded with colors for clarification...
if it was my car:
I would use a good quality #10 maxi fused wire from the batt + to the jegs switch wire marked "12V power"... I would use a #10-12 ground wire from the switch ground all the way back to the batt neg post... I would use a #12 wire from the switch to the starter solonoid.... I would use a #10 wire to the coil.... what that wiring method does is insure that the coil and ign module always has "amps available in reserve" to make the most intense spark possible...(its a over capacity, very low resistance all copper electricity path) this thread from yesterday does have a much better wiring diagram link than your book...if you do want to integrate the harness you bought to the Jeg's switch http://www.hotrodders.com/forum/cure...ok-141492.html hope that helps.... |
thanks guys, hopefully i can get all this stuff done tonight.
:thumbup: |
| All times are GMT -6. The time now is 08:25 PM. |
