im 19 and going for broke - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 03-25-2008, 11:16 AM
k20nutz's Avatar
i have 2 projects going they are both custom. the first one is my olds 425 going in a 92 c1500 (my daily driver). my next is a pulling truck its an 87 k20 with a 454 (not built yet). i want to destroke that to a 427.
Old 03-25-2008, 11:26 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders.
Old 03-25-2008, 11:31 AM
31 five window
Last journal entry: Moving along with patch panels.
Welcome. Why would you want to make a 454 into a 427?
Old 03-25-2008, 02:19 PM
Job~Rated's Avatar
Artful Dodger
Last journal entry: From behind
Welcome!
Old 03-25-2008, 02:27 PM
k20nutz's Avatar
i want to beable to pull some high rpms
Old 03-25-2008, 02:29 PM
k20nutz's Avatar
thanks all you guys
Old 03-25-2008, 08:47 PM
Welcome to Hotrodders 454s will rev hard too when built right.
Shane
Old 03-26-2008, 02:28 PM
lets cut it up's Avatar
Welcome I say build it bigger instead. 496 sounds so much better
Old 03-26-2008, 04:30 PM
k20nutz's Avatar
i want to spin high rpm but it does sound better
Old 03-26-2008, 05:49 PM
What are you planing on putting it in and how high do you plan to spin it?
Shane
Old 03-26-2008, 08:20 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Shorter strokes shouldn't be the only consideration for building a high(er) rpm engine. For most people, valvetrain upgrades and increased airflow capacity will yeild higher overall rpm capability.
A couple examples:
The 427 inch LS7 has a 4.00" stroke and has a redline of 7100 rpm
the Ford GT 5.4L has a 4.165" stroke and has a redline of 6500 rpm
Both of these engines have relatively long strokes compared to their overall displacement.
As another example, a buddy of mine races a 65 Nova with a 468" BBC. It runs 9.60s in the 1/4 and crosses the line at 7100 rpm.
Just something to think about.
Good Luck
