I'm confused - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2005, 10:08 AM
I'm confused
Sorry guys I'm really not sure what I have here. I turned in a Chevrolet 350 2 bolt as a core and recieved back a 307 block with 305 heads. Now if they bore the block .040 over like they say they do, and then the crank .010 under, what do I end up with? I dont think it is a 350! What does it sound like I got? (Besides jipped)
Old 12-28-2005, 10:15 AM
You got it, you ain't got a 350>
Old 12-28-2005, 10:22 AM
What do you end up with if you bore a 307 .040 over and the crank is undersized .010?
Old 12-28-2005, 10:46 AM
302 Z28's Avatar
Sounds to like you got ripped. I would return it in a heartbeat and make sure I got an honest 350 in return.
Vince
Old 12-28-2005, 10:56 AM
King of my Man-cave.
You got screwed.
tom
Old 12-28-2005, 12:06 PM
all you will have is a 307 that is bored 40 over...might come out to something like 310 cubic inches? not sure..but it will probalby be low compression and with some stock 305 heads it will lack much in the performance department. if you can....demand a 350..since that is what you turned in.
Old 12-28-2005, 12:36 PM
sbchevfreak's Avatar
Licenced Automotive Technician
I'd turn it in, demand my core back, and find another shop, because these guys are screwing you.
Old 12-28-2005, 10:09 PM
Well I got it fixed. They ordered me the four bolt main for no extra charge and took my two bolt as a core.
Old 12-28-2005, 10:23 PM
chevy
it would be a 317 the 307 has the same stroke as the 327 but the 307 had a small bore no power you might get some rpm out of it but bo torqe
Old 12-29-2005, 10:36 AM
I'm glad you got it sorted out, and good on ya for the freebie . It's too bad you had to go through all this, just to get the right engine. It's that type of attemted screw job that gives all automotive professions a bad name.
I am so confused. epoxy/primer/sealer/2K FrankR Body - Exterior 3 10-13-2005 05:42 PM
Confused. Skunk Engine 11 11-05-2004 02:48 PM
Confused by the oil pressure adryan16 Engine 0 05-01-2004 01:20 PM
Confused And Alarmed... KULTULZ Hotrodders Site Suggestions and Help 3 01-19-2004 02:30 PM
confused??? cranknrods Hotrodders' Lounge 7 08-11-2003 02:48 PM
