I'm in desperate need of help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2007, 12:01 AM
Hi, just started on my 50 ford tudor and ran into a huge kink. the previous owner of this car snapped the front passenger spindle and then welded it back together. I want to put front disc brakes on the car but can't afford the price right now, is there anything out there that will cross match and give me disc brakes and also fit in between the A arms????? please HELP FRANKEN50
Old 05-10-2007, 01:01 AM
aka Duke of URL
...sigh...
If on a budget, it might be best to find another spindle (unique as these had pins instead of ball joints) and buy one of those disc brake conversions that mount GM on the stock spindle.
...i can't believe i said this...
Old 05-10-2007, 06:01 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
Here's description of the installation of a kit:
http://www.customrodder.com/tech/051...nsion_upgrade/
Old 05-10-2007, 06:53 AM
Welded a spindle back together? I would not drive that accident to the end of my drive way!!!
Trees
Old 05-10-2007, 09:09 AM
BillyShope's Avatar
Philippines Cowboy
Trees
That was my thought, but I didn't say anything. I've used eighth inch plate to bring together inner and outer halves of sheet metal A-arms, but that's a lot different from welding a spindle.
Old 05-10-2007, 09:45 AM
Yeah, the previous owner was a real magician. I'm suprised he's still alive! Thanks for the help. If you have anymore ideas, I'm open to anything!
Old 05-12-2007, 10:03 AM
Dugg's Avatar
My compass doesn't point North
Welded spindle! You saved the life of the previous owner by buying the car. He should buy you a new spindle for doing so.
Old 05-14-2007, 10:31 AM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
re: I'm in desperate need of help.
Not sure I understand where you're headed, but maybe this is the first step.
Bob at Owens Salvage in Wellinton Texas. Has lots of old car stuff. Just sent me drums/hubs for a 52 Pontiac ( a direct bolt in swap for my original 41's, but heavier/wider/stronger). Bet he can find your spindle, or an interchange. Prices were very reasonable, recieved in 3 days.
they have a toll free number 800-798-2581
Desperate help needed realgreeneyes Engine 7 04-13-2007 06:19 PM
In need of desperate help laurenraquel Engine 5 05-10-2006 09:36 AM
Michigan, northern ohio guys, I'm DESPERATE for storage!!! killerformula Hotrodders' Lounge 12 10-18-2004 05:03 PM
Desperate Help Needed dsmith1279 General Rodding Tech 6 05-06-2004 07:48 AM
Fuel pump desperate help please 78 monte Engine 2 10-28-2003 08:09 PM
