I'm doing A 400 rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2013, 06:48 AM
I'm rebuilding a 400 ci sb. The heads were cracked and I have a good rebuilt set of 350 heads. They don't have the small steam holes like the 400s. Is there any way I can modify them to fit the 400 block? I have a friend who owns a machine shop and can do about any kind of machine work. Any info will be greatly appreciated. Thank you.
Old 01-19-2013, 07:12 AM
I'm doing a 400 rebuild
All you need is a set of 400 head gaskets. Here is a Wiki article on drilling the steam holes in the 350 heads. http://www.crankshaftcoalition.com/w...ck_Chevy_heads
The Following User Says Thank You to cdminter59 For This Useful Post:
cmb8065 (01-19-2013)
Old 01-19-2013, 07:51 AM
vinniekq2's Avatar
with the price of after market heads so reasonable,now is the time to step the engine up?
The Following User Says Thank You to vinniekq2 For This Useful Post:
Old 01-20-2013, 12:50 PM
I'm currently running a 406 sbc, my cylinder heads were too thick to drill out the steam holes and I didn't find not having them to hurt anything...I talked to some local guys who have a lot of experience with 400s and they have never had any overheating issues or any issues not using the steam holes...If you can have them drilled for cheap, personally I would do it just bc GM did.
Old 01-20-2013, 02:22 PM
327NUT's Avatar
You didn't say which 350 heads you have but if they are the generic smoggers I wouldn't waste my time with them....even if you port them. Personaly I would invest in a set of aftermarket heads or Vortec's, don't have to be real expensive, just more modern combustion chamber and ports.
A good set of heads will make or break a perfornance build. Whichever you choose BY ALL MEANS, drill the steam holes, they are there for a reason or Chevrolet wouldn't have spent the time and money.
Old 01-20-2013, 04:40 PM
Cant the cooling hose be run over to the drivers rear, coolant fitting, on the intake? I heard that setup does not need steam holes.
Old 01-21-2013, 12:20 AM
If you have stock 350 cylinder heads they will fit and run but will end up holding back the HP and torque of a 400. Use an after market head maybe a 195 or 205 AFR or similar size head.
TH 400 rebuild jballen454 Hotrodders' Lounge 0 02-29-2012 10:55 AM
t-400 rebuild confusion soBit Transmission - Rearend 2 04-02-2010 10:44 PM
I have to rebuild, will this get me close to 400 hp cochino12 Engine 4 11-18-2008 11:21 PM
400 rebuild 400smb_s10 Engine 9 04-20-2007 11:16 PM
Pontiac 400 rebuild PontiacTA79 Engine 13 04-27-2003 06:16 PM
