Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I'm going crazy
Thread: I'm going crazy
Old 11-21-2004, 07:12 AM
Centerline Centerline is offline
Wiki Edits: 49
If you've eliminated the ignition as a problem your only other logical source is fuel. Are you running a carb or fuel injection? What kind of pump/fuel lines are you running? Do you have a fuel pressure gauge installed?
My guess is a fuel starvation problem.
Centerline
