Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I'm going crazy
Thread: I'm going crazy
Old 11-21-2004, 08:31 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Once it goes dead, remove the air cleaner and shine a light in the carbs throat, move the throttle and see if fuel comes out of the accelerator pump shots, if you see no fuel you found the problem, it`s also possible it could be vapor locking, is the fuel line/filter close to the engine or any other high heat source? what kind of pump are you using and where is it located?
