***EDIT*** Well I see you removed the dis. and it still does the same thing. In that case see if you can watch your carb just move push on the gas a little ( at side of carb.) there might be something getting caught or the fuel not shotting in correctly. Just do this with the air cleaner off and try to watch everything very closely.
***ORG post***
Do you have an MSD 6AL with rev limiter. If so the little white chip could have the 2000 rpm chip in it and since it is a soft touch limiter it would act like it's loseing spark and or fuel. Just a thought if you just installed it. Good luck.
Chris
