Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - I'm going crazy
Thread: I'm going crazy
Old 11-21-2004, 02:39 PM
Max Keith's Avatar
Max Keith Max Keith is offline
383 stroker
There are two things that come to mind here. Bad power valve, or jetted way too lean. If you have a choke, try closing it half way. If you continue to have the problem, then I would look at the power valve. Your cap probably is vented, otherwise your engine would die on you even after idling for some time. Since you are running a double pumper, you might also check your secondaries for fuel flow as well.
