well I would leave the beans out!!! You could slip one out and the whole place could blow!!! I have been in the same boat. I had a friend of mine tell me that the fun begind when the engine is in and the tuning starts!!!! I always had a fairy tale dram that iw works like it does on the tv at the two guys garage!!! litle to my dismay I was wrong!!! The best wat is to check all you readings with a vacum gage. but what kind of cam are you running does it have a large overlap? Is your dist new used? Is your timing set new or used? are you running adjustable rockers? If so have you checked your valve lash? these can all play factors in what you are describing? Joel
