Ok, has anybody used the kits from Monster? I know you get what you pay for in these kits, but I have literally no idea what to be looking for in a kit. I'd rather stay away from Ebay in this case.
I haven't seen or read anything good about Monster.
You'll need to disassemble & inspect the Trans to know what parts will be needed. Even Master Kits don't include everything. http://www.makcotransmissionparts.com/3L80-400.html http://www.transmissionpartsusa.com/...arts_s/651.htm Build Info: ATSG Manual 400/3L80 http://www.crankshaftcoalition.com/w...0_Rebuild_tech http://www.turbobuick.com/forums/tra...-pictures.html Good Kit>> http://www.ckperformance.com/resourc...BUILDKITS.html Hughes, TCI & B&M have fairly complete Kits aswell. Video is a good idea. |
but, i just haven't got that far, and haven't done enough homework yet there are some tranny guys here that can probably get you pointed in the right direction have you read/looked at, the trans. wiki tech articles yet? |
If you decide to tackle the rebuild yourself just be very careful that you keep everything in order and make sure you put everything in the exact way it came out. Some of the bearings and large C-clips will go in both ways but are only supposed to go in one way..I didn't know this when I did mine and completely burnt 2nd and 3rd...i had to pull the trans and do it all again 200 miles later.
I just recently did my 350 Turbo,, I had a factory manual with lots of pictures, which is good , cause you may have no idea what part is called what. Lay everything out in order, make notes, especially if it's possible to put a part in wrong or backwards. Luckiy for me, I found a retired auotmotive instructor I could call if I got stuck, luckily I only had to call once .. , the factory manual is not the best guide, cause it only tells you how the engineers thought it ot be done the year the vehicle was built. A more recent book will tell you what to look for, how it actually wore, and short cuts, or the easier way to do it.
Get a master overhaul kit from ATP and a manual by Ron Sessions.
Yoy will need a special tool to compress the clutch packs, I made my own with angle iron and threaded rod.The main thing is CLEAN I mean surgically clean. |
Yea, I've been through some of the pages, though it's hard to understand anything when I haven't been into the trans yet. The Monster in a box kit is what I was referring to as well. I was curious if anybody has used one, or had good luck with it. I guess I'm going to still do LOTS of surfin, to see what else is out there and what's available. Motors are a piece of cake, but I haven't even thought about doing a transmission. No better time to learn I guess. I need to fill up the parts washer, and clean the table off. I was wondering if anybody sells an adapter for an engine stand to hold the transmissions? I saw one on a site, but nothing was ever mentioned about it.
A tip I recently heard or read about was to use something like a shower curtain rod and place the parts on there in the order you remove them. Hanging it using a couple of chains to keep it out of the way and preventing the chances of knocking everything over by accident might be a good idea too. Another one was to take an old wooden chair and make a hole in the seat large enough to snugly set the transmission into the hole, tail shaft down. It will then be properly braced during disassembly and reassembly and easier to work on. Of course, if the chair is big enough, you can drill another hole for the shower curtain rod and place parts on there as you remove them. My personal recommendation is photographing everything every step of the way. Its saved me a headache and a cussing session many times over during a carburetor rebuild.
I hope you document your rebuild on here. I'd definitely follow it. |
Definitely a good idea there. The tranny stands I'm finding look pretty cheesy, I think I may just go with the hole trick, either that or just build one. If there's any other info out there, please let me know. thanks.
I made an adapter for my engine stand... 1 1/2'' angle comes out in a curve, like a "C" to hold2 bolts to go in the lifting holes in the tranny housing.. AND you can turn it work on it .
I should probably mention that the motor I'm building is more than likely going be around 350hp. So I don't need some ballistic transmission. I personally don't like the gears slamming in as it shifts.
Does this look like the one you built Knighthawk? Here's a link, to Peterson's Offroad. http://www.4wheeloffroad.com/techart.../photo_02.html
Ok, were does one find this book by Ron Sessions? I checked Amazon and they have 16 of them. Starting at $150.00 ! WHAT? For a Used friggen book? No luck on Ebay either. The ATSG manual is $27, that's more like it. But if anybody has one of these they'd like to sell, or lease out for a reasonable rate "lol" please let me know.
| 5.7 hemi rebuild advice? | xpsyclonex2002 | Engine | 2 | 03-16-2012 07:12 AM |
| Rearend rebuild advice | JonRunaas | Transmission - Rearend | 9 | 12-21-2007 01:05 PM |
| 327 Rebuild Advice | wickster | Engine | 20 | 06-30-2006 09:33 AM |
| Advice on rearend rebuild | Vista Cruiser | Transmission - Rearend | 5 | 10-12-2004 09:43 AM |
| 350 rebuild advice | Curly | Engine | 1 | 10-05-2002 07:47 AM |
